Tutoriel étudiant vedette
Ce tutoriel est le résultat du travail hors pair d'un de nos étudiants et notre équipe iFixit le trouve particulièrement réussi.
Introduction
Allez à l'étape 1 ↓Replace your bicycle’s seat (officially known as a saddle) and upgrade your bike riding experience with this simple tutorial. Whether your seat has been mangled by a squirrel, is making your ride uncomfortable, or if you are just ready for a change, this guide will walk you through how to replace and position your new seat for maximum comfort. You can purchase a new bike seat from your local bike shop or online retailer.
A good bike seat in the correct position will not only provide a more comfortable ride, but also encourages good posture while minimizing unhealthy strain. It is important to make sure you have the best possible seat set-up for you, whether you are racing in the Olympics or just racing to class.
Ce dont vous avez besoin
Outils
Access the bolt securing the seat clamp from underneath the saddle.
Use a hex key to loosen the bolt by turning counter clockwise until the seat can be removed from the clamp.
Position the new seat's rails into the seat clamp with the clamp lying approximately flat and in the center of the rails.
Replace the bolt by twisting it in the clockwise direction while holding the top nut in place.
Turn the bolt clockwise with the hex key to partially tighten the seat so it is stable enough to hold your weight.
Test the position of the new seat by sitting on it. You should be in a neutral position (like in the photo) which allows you to comfortably reach the handlebars. You should not have any uncomfortable pressure when you sit.
Check for a moderately arched back without strain in the shoulders, wrists, or hands.
If your seat is too close to the handlebars, push the seat back and test it for comfort again.
If your seat is too far away from the handlebars, push the seat forward and test it for comfort again.
Straighten the seat by checking for parallel alignment with the bike frame.
Fully tighten the seat post bolt once you are satisfied with the positioning.
Happy riding!
3 autres ont terminé cette réparation.
