Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Bike V-Brake Pad Replacement
Ce dont vous avez besoin
  1. Bike V-Brake Pad Replacement, V-Brake Pads: étape 1, image 1 de 3 Bike V-Brake Pad Replacement, V-Brake Pads: étape 1, image 2 de 3 Bike V-Brake Pad Replacement, V-Brake Pads: étape 1, image 3 de 3
    • Position yourself directly next to the noodle (curved metal tubing) of the V-brake assembly.
    • Squeeze both arms of the V-brake assembly towards each other with the thumb and index finger of your right hand.
    • Angle the noodle downwards by simultaneously using the index and middle fingers of your left hand to gently hold the noodle in place while pushing the noodle forward with your left thumb.
    • Use your right index finger to push down the quick release hinge once it is pushed outside of the small metal tubing.
  2. Bike V-Brake Pad Replacement: étape 2, image 1 de 3 Bike V-Brake Pad Replacement: étape 2, image 2 de 3 Bike V-Brake Pad Replacement: étape 2, image 3 de 3
    • With a 5mm Allen wrench in your left hand, slightly loosen the outer nut by turning it in a counterclockwise motion.
    • While loosening the outer nut with the Allen wrench counterclockwise, support the brake pad with your right hand under it to counterbalance the force.
    • The brake pad setup will naturally fall down after slight loosening.
    • Quickly put the wrench aside and fully loosen the outer nut and following washers with your left thumb and index finger.
    • Remember the sequence they were assembled and keep the rest of your left fingers cupped under to prevent displacement of the components if they fall.
    • Take out the brake pad by using your right fingers to tilt down the pad and adjacent washers, keeping the washer sequence in mind again.
  3. Bike V-Brake Pad Replacement: étape 3, image 1 de 1
    • Remove inner washers from the brake pads.
    • Ensure that you do not lose these components as new brake pads often do not include these items. You will reuse these when assembling the new brake pad.
  4. Bike V-Brake Pad Replacement: étape 4, image 1 de 3 Bike V-Brake Pad Replacement: étape 4, image 2 de 3 Bike V-Brake Pad Replacement: étape 4, image 3 de 3
    • Obtain the new brake pad and insert the inner washers, minding the sequence, into the threaded screw attachment.
    • Insert the above attachment back into the assembly arm hole, stabilizing it with your right hand.
    • Twist in the outer components (hex nut and outer washers), minding the sequence, into the rest of the threaded screw that passes through the arm hole.
  5. Bike V-Brake Pad Replacement: étape 5, image 1 de 3 Bike V-Brake Pad Replacement: étape 5, image 2 de 3 Bike V-Brake Pad Replacement: étape 5, image 3 de 3
    • Slightly loosen the outer nut to adjust the height and angle of the brake pad to align exactly with the rim of the tire. Re-tighten the nut with the Allen wrench once finished.
    • Push the assembly arm while doing the above in order to simulate how the brake lever will engage the brake pads.
  6. Bike V-Brake Pad Replacement: étape 6, image 1 de 2 Bike V-Brake Pad Replacement: étape 6, image 2 de 2
    • Put the quick release hinge back by squeezing both assembly arms together and pushing the hinge into the metal tubing adjacent to the noodle.
Repeat the process for the other side of the tire if necessary. You may switch hand configurations if it feels more natural.
Michael Wang
Membre depuis le 01/26/23
151 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-8, Morris Winter 2023 Membre de l'équipe UC Davis, Team 1-8, Morris Winter 2023
UCD-MORRIS-W23S1G8
2 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 54
30 derniers jours : 213
Total : 3,833
