Introduction
The brush cutter contains both a smaller transaxle drive belt and a large blade/spindle belt. The transaxle drive belt must be removed first in order to access the spindle belt.
Ce dont vous avez besoin
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
Relieve the tension on the transaxle drive belt by pressing on the back end of the tensioning arm. (Alternatively, use a pry bar on the front end of the tensioning arm, or remove the tensioning spring.)
Slip the transaxle drive belt off the drive pulley.
Use a 3/8" socket or wrench to remove the four 21 mm bolts securing the cover to the deck—two at the front, and one on each side.
Insert a 3/8" drive ratchet (without any socket attached) into the square cutout in the middle of the deck idler arm.
Crank the ratchet clockwise to relieve the tension on the belt.
3 autres ont terminé cette réparation.
