Aller au contenu principal
Bionaire BAP 600 LED Night Light Replacement
Ce dont vous avez besoin
  1. Bionaire BAP 600 LED Night Light Replacement, Base/Intake: étape 1, image 1 de 1
    • Rotate the base counterclockwise, supporting the top with your opposite hand.
  2. Bionaire BAP 600 LED Night Light Replacement: étape 2, image 1 de 1
    • Pull the base away from the housing to expose the air filter.
  3. Bionaire BAP 600 LED Night Light Replacement, Air Filter: étape 3, image 1 de 1
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 LED Night Light Replacement: étape 4, image 1 de 1
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
  5. Bionaire BAP 600 LED Night Light Replacement, Outer Shell: étape 5, image 1 de 1
    • Remove all 6 screws from the LED housing.
  6. Bionaire BAP 600 LED Night Light Replacement: étape 6, image 1 de 1
    • After the 6 screws are removed, remove the LED housing from the bottom of the device by lifting it off.
  7. Bionaire BAP 600 LED Night Light Replacement: étape 7, image 1 de 1
    • Using two fingers lift the translucent LED cover from the inside. Repeat this step for the second tab.
  8. Bionaire BAP 600 LED Night Light Replacement: étape 8, image 1 de 1
    • After lifting 45 degrees, pull the translucent tab away from thee housing. Repeat this step for the second LED cover.
  9. Bionaire BAP 600 LED Night Light Replacement: étape 9, image 1 de 1
    • Locate the tab about 1 inch below the top vent. Insert a flat tool laterally past the tab and press in toward the center of the device. As the tab is being held down, pull the two halves of the egg apart to keep the shell open.
  10. Bionaire BAP 600 LED Night Light Replacement: étape 10, image 1 de 1
    • Locate the second tab on the back of the device approximately 2 inches above the power cord.
    • Insert the flat tool at a slight angle toward the left of the power cord. Depress the tab and pull the two halves of the shell apart.
  11. Bionaire BAP 600 LED Night Light Replacement: étape 11, image 1 de 1
    • Locate the bottom tab on the front side at the same height as the bottom tab on the back side.
    • Depress the tab using a flat tool at a slight angle and pull the halves apart.
  12. Bionaire BAP 600 LED Night Light Replacement: étape 12, image 1 de 1
    • Locate the last tab about one inch below the top on the front side.
    • Depress the tab using the flat tool at a slight angle and finish pulling the removable half of the shell off.
  13. Bionaire BAP 600 LED Night Light Replacement: étape 13, image 1 de 1
    • Locate the screw housing opposite of the control board, and remove the screw.
  14. Bionaire BAP 600 LED Night Light Replacement: étape 14, image 1 de 1
    • Locate the control board and grab it by the top and bottom firmly. Pull the board straight out being careful not to flex the circuit while removing.
  15. Bionaire BAP 600 LED Night Light Replacement: étape 15, image 1 de 1
    • Locate the screw that was being hidden by the control board and remove it to release the second half of the shell.
  16. Bionaire BAP 600 LED Night Light Replacement: étape 16, image 1 de 1
    • Remove the released half of the shell to finish removing the entire outer shell of the device.
  17. Bionaire BAP 600 LED Night Light Replacement, LED Night Light: étape 17, image 1 de 1
    • Next, once you see the interior of the air purifier there will be male ports with cables coming out of these ports as seen below. Thus, it is easy as taking the two wired male port (black and red) by pulling it towards you as seen below.
    • Note: There will be zip ties that are connecting the black and red wires together. Cut the zip ties.
  18. Bionaire BAP 600 LED Night Light Replacement: étape 18, image 1 de 1
    • Note: Pull the circuit board with the LED bulb underneath the air purifier gently in order to change out the LED bulb.
    • Now, use a soldering kit in order to de-solder the solder that’s on the circuit board with the LED light as seen below. Hence, once you de-solder the solder from the LED light’s wires you can move on to the next step.
  19. Bionaire BAP 600 LED Night Light Replacement: étape 19, image 1 de 1
    • Next, the last step is to gently remove the LED light from the circuit board and replace the bad LED light bulb with a new one as shown below.
Nicholas Allen Smith
Membre depuis le 10/19/16
131 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 4-4, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 304
