Aller au contenu principal
Bissell OptiClean Cyclonic Vacuum Filter Replacements
Ce dont vous avez besoin
  1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: étape 1, image 1 de 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: étape 1, image 2 de 2
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 2, image 1 de 1
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 3, image 1 de 2 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 3, image 2 de 2
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: étape 4, image 1 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: étape 4, image 2 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: étape 4, image 3 de 3
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 5, image 1 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 5, image 2 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 5, image 3 de 3
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 6, image 1 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 6, image 2 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 6, image 3 de 3
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 7, image 1 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 7, image 2 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 7, image 3 de 3
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 8, image 1 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 8, image 2 de 3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: étape 8, image 3 de 3
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
Austin Marshall
Membre depuis le 01/18/18
130 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S12-G1, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 7
Total : 778
