Aller au contenu principal
Bissell Powerglide Cordless Debris Canister Funnel Replacement
Ce dont vous avez besoin
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: étape 1, image 1 de 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: étape 1, image 2 de 3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: étape 1, image 3 de 3
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: étape 2, image 1 de 1
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: étape 3, image 1 de 1
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: étape 4, image 1 de 1
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: étape 5, image 1 de 2 Bissell Powerglide Cordless Debris Canister Funnel Replacement: étape 5, image 2 de 2
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: étape 6, image 1 de 1
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
Joseph Adam Johnson
Membre depuis le 02/05/18
511 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S21-G2, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S21-G2, Banghart Winter 2018
CPSU-BANGHART-W18S21G2
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 203
