Aller au contenu principal
Bissell SmartClean 1605 Roller Brush Replacement
Ce dont vous avez besoin
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: étape 1, image 1 de 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: étape 2, image 1 de 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: étape 3, image 1 de 3 Bissell SmartClean 1605 Roller Brush Replacement: étape 3, image 2 de 3 Bissell SmartClean 1605 Roller Brush Replacement: étape 3, image 3 de 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: étape 4, image 1 de 2 Bissell SmartClean 1605 Roller Brush Replacement: étape 4, image 2 de 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Austin Maranville
Membre depuis le 09/26/17
117 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G4, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 membres
5 tutoriels rédigés
13 commentaires
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Réponse
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Réponse
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Réponse
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 1,030
