Aller au contenu principal
Bissell SpotBot Pet Hose Assembly Replacement
Ce dont vous avez besoin
  1. Bissell SpotBot Pet Hose Assembly Replacement, Cleaning solution tank: étape 1, image 1 de 1
    • Remove cleaning solution tank.
  2. Bissell SpotBot Pet Hose Assembly Replacement, Waste storage tank: étape 2, image 1 de 1
    • Remove waste storage tank.
  3. Bissell SpotBot Pet Hose Assembly Replacement, Top cover: étape 3, image 1 de 1
    • Remove (4) Phillips head screws.
  4. Bissell SpotBot Pet Hose Assembly Replacement, Top cover removal: étape 4, image 1 de 1
    • Remove top cover. Unplug ribbon cable from control board and set top aside.
  5. Bissell SpotBot Pet Hose Assembly Replacement: étape 5, image 1 de 2 Bissell SpotBot Pet Hose Assembly Replacement: étape 5, image 2 de 2
    • Remove the two screws and gently move white box with wires out of the way.
  6. Bissell SpotBot Pet Hose Assembly Replacement, Solution tubing removal: étape 6, image 1 de 1
    • Locate end of clear rubber tubing and remove clamp with pliers. It is nearly impossible to get the hose end off of the hose barb, so I just cut the hose close to the barb, then gently scored the tubing left on the barb to get it off.
    • Remove hose assembly by gently twisting up on hose. This end is just snug-fit with 2 O-Rings.
    • Install new hose assembly by adding a little silicone-based grease on the 2 o-rings and inserting the hose end into the hole by the waste tank inlet port. Then attatch the clear tubing on the barb, then replace the hose clamp.
5 autres ont terminé cette réparation.
Tim Lough
Membre depuis le 07/18/17
301 Réputation
1 tutoriel rédigé
8 commentaires
Thanks Tim! You made that very easy and straight forward. I was done in 10 minutes.
David Root - Réponse
Not a problem, glad it worked for you! Mine is still going strong after 2 years.
Tim Lough -
Worked like a charm. You had very good pictures and easy to understand explanation
Bruce Bradford - Réponse
This is great thanks!  I got as far removing the clamps and was afraid to move forward, my replacement hose did not come with new clamps and I am worried I will break them.  This is my first time working with clamps.  I searched the internet and found your site.  This is wonderful, thank you very much.
brigadoonsetters - Réponse
Breathed new life into our SpotBot with these instructions, thank you!!
Anthony Clark - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 89
Total : 6,881
