Aller au contenu principal
Bissell SpotClean ProHeat 5207U Float Stack Replacement
  1. Bissell SpotClean ProHeat 5207U Float Stack Replacement, Float Stack: étape 1, image 1 de 1
    • Ensure Bissell SpotClean ProHeat is unplugged.
    • Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
  2. Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 2, image 1 de 2 Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 2, image 2 de 2
    • Remove the dirty water tank. It is the tank on the right.
    • The tank reads "dirty" on the bottom on the inner edge.
  3. Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 3, image 1 de 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 3, image 2 de 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 3, image 3 de 3
    • Rotate the bottom of the float stack counterclockwise until the float stack comes lose.
    • Remove the float stack from the tank.
  4. Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 4, image 1 de 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 4, image 2 de 3 Bissell SpotClean ProHeat 5207U Float Stack Replacement: étape 4, image 3 de 3
    • Grab the float on the float Stack assembly
    • Slide the float down towards the base.
    • Remove float and clean any debris found.
2 autres ont terminé cette réparation.
Edy Mendoza
Membre depuis le 09/13/23
422 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 169
