Introduction
Is your Bissell Spot Clean Pro Heat mixing the dirty and clean water, resulting in dirty water being reused to clean surfaces? If so, it might be due to the float stack being stuck or broken. Follow this guide to replace or clean the float stack on your Bissell Spot Clean Pro Heat.
Position your hand vacuum so that you can see the text at the bottom saying "SpotClean ProHeat."
2 autres ont terminé cette réparation.
