Aller au contenu principal
Bissell SpotClean ProHeat 5207U Water Pump Replacement
Ce dont vous avez besoin
  1. Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: étape 1, image 1 de 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: étape 1, image 2 de 2
    • Ensure the device is unplugged.
    • Make sure that you have removed both the clean and dirty water tank so that you can unscrew the proper screws.
    • Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
  2. Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 2, image 1 de 3 Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 2, image 2 de 3 Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 2, image 3 de 3
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
    • Remove the plastic lip that was previously held by the screws.
  3. Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 3, image 1 de 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 3, image 2 de 2
    • Using pliers, pinch the hose clamp tabs together, then remove the clamp.
    • Remove the water hose from the water pump.
  4. Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 4, image 1 de 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 4, image 2 de 2
    • Remove the green wire by pulling it away from the pump.
    • Be careful not to bend where the wire is plugged into.
  5. Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 5, image 1 de 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 5, image 2 de 2
    • Pull the clear hose away from the pump until it is removed.
  6. Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 6, image 1 de 2 Bissell SpotClean ProHeat 5207U Water Pump Replacement: étape 6, image 2 de 2
    • Remove the zip tie from the water pump.
    • Replace the old water pump with the new water pump.
2 autres ont terminé cette réparation.
Trenton Hedgecock
Membre depuis le 09/13/23
178 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 20
Total : 153
