Aller au contenu principal
Black and Decker 3-Cup Rice Cooker Button Mechanism Repair
Ce dont vous avez besoin
  1. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Lid and Bowl: étape 1, image 1 de 1
    • Make sure the device is unplugged before beginning disassembly!
    • Lift the lid and bowl from the top of the device.
  2. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Turn the Device Upside-Down: étape 2, image 1 de 1
    • Turn the device upside-down, so that the four legs of the device point upwards.
  3. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Rubber Cushions: étape 3, image 1 de 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Rubber Cushions: étape 3, image 2 de 2
    • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
  4. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Spanning Screw: étape 4, image 1 de 1
    • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
  5. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Leg Screws: étape 5, image 1 de 1
    • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
    • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
  6. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Remove the Brass Plate: étape 6, image 1 de 1
    • Lift the brass plate off the device and set it aside.
  7. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Color the Wires: étape 7, image 1 de 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Color the Wires: étape 7, image 2 de 2
    • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
    • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
    • Unscrew the screw at the junction near the opposite side of the device from the front panel.
    • Label each of the two wires at this junction with a single color of tape.
  8. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Second Wire Junction: étape 8, image 1 de 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Second Wire Junction: étape 8, image 2 de 2
    • Unscrew the screw at the junction just clockwise from the button panel.
    • Label the three wires of this junction with tape of a second color.
  9. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Third Wire Junction: étape 9, image 1 de 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Label the Third Wire Junction: étape 9, image 2 de 2
    • Unscrew the screw from the wire junction just behind the front panel.
    • Label the three wires at this junction with a third color of tape.
  10. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Check the Locking Beam: étape 10, image 1 de 1
    • On the inside of the device, there is a silver-colored beam leading to the center with a U-shaped brass beam poking through it.
    • The U-shaped brass beam should be bent outwards so that it cannot fit through the hole in the silver-colored beam.
  11. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Position the Brass Beam: étape 11, image 1 de 2 Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Position the Brass Beam: étape 11, image 2 de 2
    • If the brass beam is not poking through the silver-colored beam, you will need to position it so that it is.
    • Position the brass beam below the hole in the silver-colored beam and push the silver-colored beam into it, so that the brass beam pokes through.
  12. Black and Decker 3-Cup Rice Cooker Button Mechanism Repair, Bend the Brass Beam: étape 12, image 1 de 1
    • If the brass beam can't fit through the hole in the silver-colored beam, use pliers to bend the brass beam outwards so that it does not fit through the hole in the silver-colored beam.
Steven Gerick
Membre depuis le 09/22/14
403 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-1, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 20
Total : 2,812
