Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Black and Decker 9074 Type 4 Battery Replacement
Ce dont vous avez besoin
  1. Black and Decker 9074 Type 4 Battery Replacement, Battery: étape 1, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement, Battery: étape 1, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement, Battery: étape 1, image 3 de 3
    • Black & Decker 9074 type 4 screwdriver that no longer holds a charge.
    • Main pieces to work on for disassembly
    • Remove the clip that holds the transmission to the body. Insert a 6mm (1/4") flat tip screwdriver underneath the clip, gently move clip upward.
  2. Black and Decker 9074 Type 4 Battery Replacement: étape 2, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 2, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 2, image 3 de 3
    • Once the clip is removed the transmission can be pulled of the body.
    • Move transmission away from body
    • Planetary gears inside the transmission look clean and complete.
  3. Black and Decker 9074 Type 4 Battery Replacement: étape 3, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 3, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 3, image 3 de 3
    • Remove plastic washer that is situated between the transmission and the body.
    • These are the three screws that need to be removed.
    • Use a Phillips #1 screwdriver on those three screws
  4. Black and Decker 9074 Type 4 Battery Replacement: étape 4, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 4, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 4, image 3 de 3
    • Three Phillips screws 7/8" long removed.
    • Separate the two body halves.
    • Battery, charging port and motor are clearly seen. These are just laid into the bottom half and can be easily removed.
  5. Black and Decker 9074 Type 4 Battery Replacement: étape 5, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 5, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 5, image 3 de 3
    • The motor is held to the contact carrier by two elongated contacts. Clearly visible is a charging Diode as we as plenty of corrosion on the positive contact.
    • Remove motor by simply pulling it away from the contact carrier
    • View of the wiring with motor removed.
  6. Black and Decker 9074 Type 4 Battery Replacement: étape 6, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 6, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 6, image 3 de 3
    • Top view of the wiring.
    • Use small needle nose pliers to remove cable connector from positive contact of the battery.
    • Positive wiring removed from battery.
  7. Black and Decker 9074 Type 4 Battery Replacement: étape 7, image 1 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 7, image 2 de 3 Black and Decker 9074 Type 4 Battery Replacement: étape 7, image 3 de 3
    • Remove the negative (bottom) wire from battery. Gently pull it off the cable connector. Hold the wire close to the connector for removal.
    • All wiring separated from the battery. It is now ready to be replaced.
    • These are all the parts disassembled for this job.
9 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
839 425 Réputation
123 tutoriels rédigés
3 commentaires de tutoriel
thanks. It is also useful for old TYPE 1 model 9018. But where can you find the battery?
Biller koby - Réponse
Biller koby of course like so many other things, the battery is no longer available. But we have a fix for that as well. Check this guide Repairing Black and Decker 9074 Screwdriver Battery
oldturkey03 -
i just put a 18650 lithium battery and works perfectly
Federico Maci -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 91
Total : 16,043
