Aller au contenu principal
Black and Decker BDERO100 Holder Brush and Spring Replacement
Ce dont vous avez besoin
  1. Black and Decker BDERO100 Holder Brush and Spring Replacement, Chassis: étape 1, image 1 de 2 Black and Decker BDERO100 Holder Brush and Spring Replacement, Chassis: étape 1, image 2 de 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 2, image 1 de 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 2, image 2 de 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 3, image 1 de 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 3, image 2 de 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 4, image 1 de 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 4, image 2 de 2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Holder Brush and Spring Replacement, Holder Brush and Spring: étape 5, image 1 de 3 Black and Decker BDERO100 Holder Brush and Spring Replacement, Holder Brush and Spring: étape 5, image 2 de 3 Black and Decker BDERO100 Holder Brush and Spring Replacement, Holder Brush and Spring: étape 5, image 3 de 3
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  6. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 6, image 1 de 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 6, image 2 de 2
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  7. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 7, image 1 de 1
    • Identify the white cables connected to the holder brush and spring.
  8. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 8, image 1 de 2 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 8, image 2 de 2
    • Hold the motor and gently pull to remove from chassis.
  9. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 9, image 1 de 3 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 9, image 2 de 3 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 9, image 3 de 3
    • Remove the wire connected to the brush holder from the motor by pulling gently.
  10. Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 10, image 1 de 3 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 10, image 2 de 3 Black and Decker BDERO100 Holder Brush and Spring Replacement: étape 10, image 3 de 3
    • Make a note of where each wire should be, you will avoid making wiring mistakes when assembling the device.
Irene Zubillaga
Membre depuis le 02/10/16
617 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 1,643
