Aller au contenu principal
Black and Decker BDERO100 Power Cord Replacement
Ce dont vous avez besoin
  1. Black and Decker BDERO100 Power Cord Replacement, Chassis: étape 1, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement, Chassis: étape 1, image 2 de 2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Cord Replacement: étape 2, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement: étape 2, image 2 de 2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Cord Replacement: étape 3, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement: étape 3, image 2 de 2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Cord Replacement: étape 4, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement: étape 4, image 2 de 2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Cord Replacement, Power Cord: étape 5, image 1 de 3 Black and Decker BDERO100 Power Cord Replacement, Power Cord: étape 5, image 2 de 3 Black and Decker BDERO100 Power Cord Replacement, Power Cord: étape 5, image 3 de 3
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  6. Black and Decker BDERO100 Power Cord Replacement: étape 6, image 1 de 3 Black and Decker BDERO100 Power Cord Replacement: étape 6, image 2 de 3 Black and Decker BDERO100 Power Cord Replacement: étape 6, image 3 de 3
    • Gently pull the white cable that connects the power cord to the motor to detach it.
  7. Black and Decker BDERO100 Power Cord Replacement: étape 7, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement: étape 7, image 2 de 2
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  8. Black and Decker BDERO100 Power Cord Replacement: étape 8, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement: étape 8, image 2 de 2
    • Select the cable that connects the power button to the power button.
  9. Black and Decker BDERO100 Power Cord Replacement: étape 9, image 1 de 1
    • Expose the cable and lock system by removing the cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  10. Black and Decker BDERO100 Power Cord Replacement: étape 10, image 1 de 2 Black and Decker BDERO100 Power Cord Replacement: étape 10, image 2 de 2
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button.
Irene Zubillaga
Membre depuis le 02/10/16
617 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Sullivan Spring 2016 Membre de l'équipe USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 630
