Aller au contenu principal
Black and Decker BDH9600CHV Motor Replacement
Ce dont vous avez besoin
  1. Black and Decker BDH9600CHV Motor Replacement, Motor: étape 1, image 1 de 3 Black and Decker BDH9600CHV Motor Replacement, Motor: étape 1, image 2 de 3 Black and Decker BDH9600CHV Motor Replacement, Motor: étape 1, image 3 de 3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Motor Replacement: étape 2, image 1 de 1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Motor Replacement: étape 3, image 1 de 3 Black and Decker BDH9600CHV Motor Replacement: étape 3, image 2 de 3 Black and Decker BDH9600CHV Motor Replacement: étape 3, image 3 de 3
    • Pull the housing apart
    • When you pull apart the housing pieces could fall out. Be sure to keep track of them.
    • Remove the motor unit from the housing
    • Note that the black disk needs to be firmly pulled it will resist, but can be pulled directly off of the pin if it is pulled hard enough.
  4. Black and Decker BDH9600CHV Motor Replacement: étape 4, image 1 de 3 Black and Decker BDH9600CHV Motor Replacement: étape 4, image 2 de 3 Black and Decker BDH9600CHV Motor Replacement: étape 4, image 3 de 3
    • Remove the motor from the circuit board.
    • The motor makes contact with the board at 2 points. These may be bent or distorted. Straighten them with a pair of needle nose pliers in order to remove.
Ivette Muzquiz
Membre depuis le 11/06/17
349 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Harley Fall 2017 Membre de l'équipe IUPUI, Team S1-G4, Harley Fall 2017
IUPUI-HARLEY-F17S1G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 18
Total : 2,353
