Aller au contenu principal
Introduction
This guide will take you through the process of replacing the power cord on the Black and Decker BV2500 Type 4. Without a power cord that works, the device will not turn on.
  1. Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
    • Locate and unscrew the six 20 mm Phillips #2 screws in the black plastic casing (clamshell) with a Phillips #2 screwdriver.
  2. Using your hands, remove the blower tube and clamshell. To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver. Use your hands to lift off the side of the orange casing with the screws facing you.
    • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
    • Use your hands to lift off the side of the orange casing with the screws facing you.
  5. Locate the switch. Remove the 2 black and white wires with blue casings from the switch.
    • Locate the switch.
    • Remove the 2 black and white wires with blue casings from the switch.
    • Using your hands, push in the sides of the switch and slide out the wires.
  6. Unscrew the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog) with a Phillips #2 screwdriver.
    • Unscrew the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog) with a Phillips #2 screwdriver.
  7. Slide the power cord support off the power cord in the direction of the leads. Use your hands to pull the power cord out of the device with the lead end coming out last. Use your hands to pull the power cord out of the device with the lead end coming out last.
    • Slide the power cord support off the power cord in the direction of the leads.
    • Use your hands to pull the power cord out of the device with the lead end coming out last.
Angelica Chow
Membre depuis le 25/01/2014
363 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 9-29, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 27
Total : 1,615
