Aller au contenu principal
Black and Decker DustBuster 15.6V Nozzle Brush Replacement
Ce dont vous avez besoin
  1. Black and Decker DustBuster 15.6V Nozzle Brush Replacement, Nozzle Brush: étape 1, image 1 de 1
    • Lift Nozzle Brush until it clicks into fully erect position.
  2. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: étape 2, image 1 de 1
    • Apply a gentle, equal pressure outward, to the inside of both brush legs.
  3. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: étape 3, image 1 de 1
    • Remove one of the leg prongs from the hole it is inserted into.
  4. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: étape 4, image 1 de 1
    • Rotate the free leg forwards or backwards from the hole.
    • This relieves the pressure from the inside of the legs allowing you to freely remove the last leg from its hole.
  5. Black and Decker DustBuster 15.6V Nozzle Brush Replacement: étape 5, image 1 de 1
    • Check each leg hole for debris and clear whats needed.
    • Insert a leg of the new brush into the correct hole, so the brush will click into its erect position.
    • Slide the other leg into its respective hole.
Jacob
Membre depuis le 03/15/17
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S6-G1, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S6-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G1
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 350
