Aller au contenu principal
Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
Ce dont vous avez besoin
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: étape 1, image 1 de 1
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: étape 2, image 1 de 1
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: étape 3, image 1 de 1
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: étape 4, image 1 de 1
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
Roberto Perez
Membre depuis le 03/31/17
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S6-G1, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S6-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G1
4 membres
9 tutoriels rédigés
Un commentaire
Where can I buy a new suction seal.
Alison Junk - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 27
Total : 2,348
