Aller au contenu principal
Black and Decker Dustbuster CHV1510 Battery Pack Replacement
Ce dont vous avez besoin
  1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: étape 1, image 1 de 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: étape 1, image 2 de 2
    • Remove the six exterior 2 mm Phillips #0 screws securing the 2 halves of the white shell together.
  2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 2, image 1 de 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 2, image 2 de 2
    • Remove nozzle by pressing two blue buttons on the side of the nozzle
  3. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 3, image 1 de 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 3, image 2 de 2
    • Remove the dustbin by pressing the blue button on the vacuum's handle and lift the bin from the vacuum.
  4. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 4, image 1 de 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 4, image 2 de 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 4, image 3 de 3
    • Gently separate the two halves by pulling them apart, revealing the 14 cell battery pack behind the motor.
  5. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 5, image 1 de 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 5, image 2 de 2
    • Removal of the battery pack is a tool-less process, lift the battery pack out of the vacuum gently, notice there are two wires connected to the battery.
  6. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 6, image 1 de 2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: étape 6, image 2 de 2
    • Disconnect the red wire from the battery pack (pull do not twist!) and do the same with the black wire
  7. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: étape 7, image 1 de 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: étape 7, image 2 de 3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: étape 7, image 3 de 3
    • Holding the battery pack firmly, disconnect the red and black wires from the battery pack by pulling them gently.
2 autres ont terminé cette réparation.
Miguel Vilao
Membre depuis le 11/09/17
376 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S7-G6, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S7-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G6
3 membres
3 tutoriels rédigés
Un commentaire
The battery pack in no longer available and the 14 cells would cost more than a brand new dustbuster (Feb 25, 2021). I managed to get almost 10-years out of my CHV1510.
glenn.watkins - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 31
Total : 4,099
