Aller au contenu principal
Black and Decker Dustbuster HNVC115J22 Motor Replacement
Ce dont vous avez besoin
  1. Black and Decker Dustbuster HNVC115J22 Motor Replacement, Motor: étape 1, image 1 de 2 Black and Decker Dustbuster HNVC115J22 Motor Replacement, Motor: étape 1, image 2 de 2
    • Press the button above the dustbin and separate the dustbin from the handle.
  2. Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 2, image 1 de 1
    • Remove five screws from the handle using a Phillips #1 screwdriver.
  3. Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 3, image 1 de 2 Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 3, image 2 de 2
    • Pry open the two halves of the case.
  4. Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 4, image 1 de 2 Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 4, image 2 de 2
    • Lift the motor and circuitry out of the plastic casing using your hands.
    • Pry out the PCB using a nylon spudger.
  5. Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 5, image 1 de 1
    • Separate the motor leads from the PCB with a pair of needle nose pliers.
    • Be careful not to break the new motor leads as they can be fragile.
  6. Black and Decker Dustbuster HNVC115J22 Motor Replacement: étape 6, image 1 de 1
    • Using a pair of pliers, insert the metal prongs of the new motor into the PCB.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 731
