Aller au contenu principal
Black and Decker IR02V-T Power Cord Replacement
Ce dont vous avez besoin
  1. Black and Decker IR02V-T Power Cord Replacement, Power Cord: étape 1, image 1 de 3 Black and Decker IR02V-T Power Cord Replacement, Power Cord: étape 1, image 2 de 3 Black and Decker IR02V-T Power Cord Replacement, Power Cord: étape 1, image 3 de 3
    • Remove the two silicone covers which encase the screws.
    • Remove both 1 mm screws using a T5 Torx screwdriver.
    • Pry open the plastic cover starting from the top of the iron.
  2. Black and Decker IR02V-T Power Cord Replacement: étape 2, image 1 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 2, image 2 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 2, image 3 de 3
    • Remove both caps from the end of the wire by using pliers.
    • Unfold the metal in the caps using the pliers to release the exposed wire.
    • Remove the two 1 mm screws holding down the wire using a Phillips #00 screwdriver.
    • Once the wires are exposed separate and fold to opposite sides.
  3. Black and Decker IR02V-T Power Cord Replacement: étape 3, image 1 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 3, image 2 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 3, image 3 de 3
    • Remove the old power cord from the iron completely.
    • Insert the new cord through the plastic cover and hole of the iron as demonstrated in the image.
  4. Black and Decker IR02V-T Power Cord Replacement: étape 4, image 1 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 4, image 2 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 4, image 3 de 3
    • Expose about half an inch of wire by removing the silicone that encases it.
    • Tie the new wire into a knot and connect the wires accordingly.
    • Place the caps over the exposed wire and use pliers to tighten the metal to secure the wire.
  5. Black and Decker IR02V-T Power Cord Replacement: étape 5, image 1 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 5, image 2 de 3 Black and Decker IR02V-T Power Cord Replacement: étape 5, image 3 de 3
    • Once the caps are over the wires add the two 1 mm Phillips screws along with the small base plate which secures the wire.
    • When all wires are secure place the plastic cover and screw back in the 1mm Torx screws.
Ligne d'arrivée
Kevin B
Membre depuis le 11/10/22
146 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-28, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 2-28, Briggs Fall 2022
CSULA-BRIGGS-F22S2G28
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 44
Total : 956
