Aller au contenu principal
Black and Decker JE2200B Disassembly
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
  1. Black and Decker JE2200B Disassembly, Unlocking Latches: étape 1, image 1 de 2 Black and Decker JE2200B Disassembly, Unlocking Latches: étape 1, image 2 de 2
    • To undo the locking latches: Pull outwards at the bottom of each latch to detach them from the groove on the cover .
  2. Black and Decker JE2200B Disassembly, Removing the Cover: étape 2, image 1 de 2 Black and Decker JE2200B Disassembly, Removing the Cover: étape 2, image 2 de 2
    • To remove the cover: Take out the feeder, hold the chute firmly and pull up the cover.
  3. Black and Decker JE2200B Disassembly, Remove Pulp Separator: étape 3, image 1 de 1
    • To remove the pulp container: Hold the juice spout with one hand and the back edge of the pulp separator with the other hand. Pull it up while making sure that the cutter/strainer is kept in place
  4. Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: étape 4, image 1 de 3 Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: étape 4, image 2 de 3 Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: étape 4, image 3 de 3
    • To remove the cutter/strainer: Hold the juice spout with one hand and clutch the edge of the cutter/strainer with the other hand; pull it out slowly.
    • ' The teeth on the cutter/strainer are very sharp. '
  5. Black and Decker JE2200B Disassembly, Remove Pulp Container: étape 5, image 1 de 1
    • To remove the pulp separator: Hold the sides firmly and pull the container out.
To reassemble your device, follow this guide in reverse order.
Bhavika Shah
Membre depuis le 08/27/15
331 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-5, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 696
