Aller au contenu principal
Black and Decker JS660 Angle Lock Replacement
Ce dont vous avez besoin
  1. Black and Decker JS660 Angle Lock Replacement, Base: étape 1, image 1 de 2 Black and Decker JS660 Angle Lock Replacement, Base: étape 1, image 2 de 2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Lock Replacement: étape 2, image 1 de 1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Lock Replacement: étape 3, image 1 de 2 Black and Decker JS660 Angle Lock Replacement: étape 3, image 2 de 2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Lock Replacement, Angle Lock: étape 4, image 1 de 3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: étape 4, image 2 de 3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: étape 4, image 3 de 3
    • Remove the screw marked and the lever will slide out easily
    • The black screw must next be removed.
    • After removing the screw the lever will slide out of the jigsaw.
Andrew Khouri
Membre depuis le 02/08/16
468 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 6-2, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 6-2, Eyestone Spring 2016
USFT-EYESTONE-S16S6G2
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 173
