Aller au contenu principal
Black and Decker JS660 Power Cord Replacement
Ce dont vous avez besoin
  1. Black and Decker JS660 Power Cord Replacement, Housing Disassembly: étape 1, image 1 de 2 Black and Decker JS660 Power Cord Replacement, Housing Disassembly: étape 1, image 2 de 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Power Cord Replacement: étape 2, image 1 de 1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Power Cord Replacement, Power Cord: étape 3, image 1 de 1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Power Cord Replacement: étape 4, image 1 de 1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Power Cord Replacement: étape 5, image 1 de 1
    • Gently remove the black and white cord from the trigger assembly.
matt murray
Membre depuis le 01/27/17
682 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 22-9, Maness Winter 2017 Membre de l'équipe Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 805
