Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Black and Decker LDX 120C Gear Replacement
Ce dont vous avez besoin
  1. Black and Decker LDX 120C Gear  Replacement, Outer Case: étape 1, image 1 de 1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Gear  Replacement: étape 2, image 1 de 1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Gear  Replacement: étape 3, image 1 de 1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Gear  Replacement: étape 4, image 1 de 1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Gear  Replacement: étape 5, image 1 de 1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Gear  Replacement: étape 6, image 1 de 1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Gear  Replacement: étape 7, image 1 de 1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Gear  Replacement, Gear: étape 8, image 1 de 1
    • After following the prerequisite guide you will be able to access the interior components of the drill.
  9. Black and Decker LDX 120C Gear  Replacement: étape 9, image 1 de 1
    • Gently remove the top part (motor and chuck) from the rest of the drill.
  10. Black and Decker LDX 120C Gear  Replacement: étape 10, image 1 de 1
    • Make sure you do that with care so that the connection doesn't get damaged.
  11. Black and Decker LDX 120C Gear  Replacement: étape 11, image 1 de 1
    • To be able to get into the gears you will need to separate the motor from the rest.
    • And then you will be able to access the gears which is located between the motor and the chuck.
  12. Black and Decker LDX 120C Gear  Replacement: étape 12, image 1 de 1
    • Twist the gauge to change between the gear.
    • If you don't hear a clicking sound then check the gears.
  13. Black and Decker LDX 120C Gear  Replacement: étape 13, image 1 de 1
    • Twist the gear and see if the three gears rotate without jamming.
  14. Black and Decker LDX 120C Gear  Replacement: étape 14, image 1 de 1
    • Check if any gear is chipped or broken in any way.
    • If it is then you will need to change the broken gear.
  15. Black and Decker LDX 120C Gear  Replacement: étape 15, image 1 de 1
    • Using the spudger place it under the gear as illustrated.
  16. Black and Decker LDX 120C Gear  Replacement: étape 16, image 1 de 1
    • The gear will remove with just a little amount of force.
  17. Black and Decker LDX 120C Gear  Replacement: étape 17, image 1 de 1
    • The gear has been removed and now can be replaced by another gear.
jeffrey zakka
Membre depuis le 02/09/16
777 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 11-5, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
5 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 32
Total : 2,422
