Aller au contenu principal
Black and Decker LDX 120C Motor Replacement
Ce dont vous avez besoin
  1. Black and Decker LDX 120C Motor  Replacement, Outer Case: étape 1, image 1 de 1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Motor  Replacement: étape 2, image 1 de 1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Motor  Replacement: étape 3, image 1 de 1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Motor  Replacement: étape 4, image 1 de 1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Motor  Replacement: étape 5, image 1 de 1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Motor  Replacement: étape 6, image 1 de 1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Motor  Replacement: étape 7, image 1 de 1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Motor  Replacement, Motor: étape 8, image 1 de 1
    • After following the prerequisite guide the interior components can now be accessed.
    • The motor is the silver cylinder in the top part of the drill.
  9. Black and Decker LDX 120C Motor  Replacement: étape 9, image 1 de 1
    • Separate the top from the rest of the components.
  10. Black and Decker LDX 120C Motor  Replacement: étape 10, image 1 de 1
    • Do this carefully so that no damage is done to the connection.
  11. Black and Decker LDX 120C Motor  Replacement: étape 11, image 1 de 1
    • Check if the connection from the motor to the trigger is connected.
    • Then check if the connection to the chip is not intact.
    • If the connection is okay then the motor is probably weak and needs to be replaced.
  12. Black and Decker LDX 120C Motor  Replacement: étape 12, image 1 de 1
    • To remove the motor simply twist as illustrated in the picture.
    • The way the motor is designed for the LDX 120C is that it is protected inside the aluminum cylinder which works as a magnet.
    • The inside part of the motor can not be accessed, so you will have to replace the entire motor.
  13. Black and Decker LDX 120C Motor  Replacement: étape 13, image 1 de 1
    • Unscrew the black plastic support from the motor.
jeffrey zakka
Membre depuis le 02/09/16
735 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 11-5, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
5 membres
6 tutoriels rédigés
6 commentaires
Now What?? I have it apart
Jim - Réponse
I own one of these drills while trying to replace the keyless chuck I ruined the shaft it goes on can you tell me How to replace the threaded shaft and where to get replacement parts
irgspllc - Réponse
I own one of these drills I need to replace the keyless chuck and the threaded shaft it goes on. Please tell me how and where to find replacement parts
irgspllc - Réponse
It would have been "nice" if iFixIt could have provided info (ie. part/model number) for the motor.
Robb Ryan - Réponse
Great tutorial on how to take it apart. I'm having trouble finding the exact replacement, at least according to the numbers on the motor. Can someone verify what the correct replacement model number is? Also, is it possible to replace it with a brushless motor?
Nicholas Miller - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 14
30 derniers jours : 38
Total : 2,829
