Aller au contenu principal
Black and Decker LDX172C Battery Charge Port Replacement
Ce dont vous avez besoin
  1. Black and Decker LDX172C Battery Charge Port Replacement, Battery Charge Port: étape 1, image 1 de 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Charge Port Replacement: étape 2, image 1 de 1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Charge Port Replacement: étape 3, image 1 de 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the battery charging port in the base of the drill.
  4. Black and Decker LDX172C Battery Charge Port Replacement: étape 4, image 1 de 1
    • Remember that the battery may still have a charge. To avoid electrical shock, it is a good idea to disconnect the battery before modifying any connections on the charging port. You can find how to disconnect the battery here
    • Remove the soldered wire connections as marked.
    • Re-solder the wire connections to the new charge port and insert the charge port back into its proper location.
    • Repeat steps in reverse to reassemble.
2 autres ont terminé cette réparation.
Eric Miessen
Membre depuis le 02/13/16
182 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-3, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 membres
6 tutoriels rédigés
Un commentaire
Hi where can I get the replacement charge port from. Thanks
adam mellor - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 2,544
