Aller au contenu principal
Black and Decker PS1800 Motor Replacement
Ce dont vous avez besoin
  1. Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: étape 1, image 1 de 2 Black and Decker PS1800 Motor Replacement, Open the Outer Drill Case: étape 1, image 2 de 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Motor Replacement: étape 2, image 1 de 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Motor Replacement, Disconnect Motor: étape 3, image 1 de 3 Black and Decker PS1800 Motor Replacement, Disconnect Motor: étape 3, image 2 de 3 Black and Decker PS1800 Motor Replacement, Disconnect Motor: étape 3, image 3 de 3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Motor Replacement: étape 4, image 1 de 1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Motor Replacement: étape 5, image 1 de 2 Black and Decker PS1800 Motor Replacement: étape 5, image 2 de 2
    • Remove the motor from the transmission assembly, as pictured.
Christian Aldrich
Membre depuis le 10/12/16
253 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-3, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 26
Total : 1,867
