Aller au contenu principal
Black and Decker PS1800 Transmission Replacement
Ce dont vous avez besoin
  1. Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: étape 1, image 1 de 2 Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: étape 1, image 2 de 2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Transmission Replacement: étape 2, image 1 de 1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: étape 3, image 1 de 3 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: étape 3, image 2 de 3 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: étape 3, image 3 de 3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Transmission Replacement: étape 4, image 1 de 1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Transmission Replacement: étape 5, image 1 de 2 Black and Decker PS1800 Transmission Replacement: étape 5, image 2 de 2
    • Remove the motor from the transmission assembly, as pictured.
  6. Black and Decker PS1800 Transmission Replacement, Transmission: étape 6, image 1 de 3 Black and Decker PS1800 Transmission Replacement, Transmission: étape 6, image 2 de 3 Black and Decker PS1800 Transmission Replacement, Transmission: étape 6, image 3 de 3
    • Unscrew the torque adjuster from the transmission by removing the screws highlighted in the lefthand picture.
  7. Black and Decker PS1800 Transmission Replacement: étape 7, image 1 de 1
    • Align the new transmission gears with the motor’s gears.
    • Reattach the transmission and motor by rescrewing the initial screws.
  8. Black and Decker PS1800 Transmission Replacement: étape 8, image 1 de 2 Black and Decker PS1800 Transmission Replacement: étape 8, image 2 de 2
    • Reconnect the torque adjuster to the transmission by following the procedure seen in step 6.
  9. Black and Decker PS1800 Transmission Replacement: étape 9, image 1 de 1
    • Reconnect black and red wires onto the motor and place the motor, transmission and torque adjuster back onto their initial location.
  10. Black and Decker PS1800 Transmission Replacement: étape 10, image 1 de 1
    • Reconnect the clamshell.
    • Press trigger to make sure the new transmission works.
    • Press and hold the clam-shell to assure it will not drop while testing.
David Nawl
Membre depuis le 10/19/16
279 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-3, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 2-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G3
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 1,471
