Aller au contenu principal
Black and Decker Pivot MAX Battery Replacement
Ce dont vous avez besoin
  1. Black and Decker Pivot MAX Battery Replacement, Battery: étape 1, image 1 de 2 Black and Decker Pivot MAX Battery Replacement, Battery: étape 1, image 2 de 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: étape 2, image 1 de 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: étape 3, image 1 de 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: étape 4, image 1 de 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: étape 5, image 1 de 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
25 autres ont terminé cette réparation.
Jesse Sipes
Membre depuis le 11/06/17
586 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S5-G6, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 membres
5 tutoriels rédigés
27 commentaires
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - Réponse
Where do I get the cells to replace the old ones?
Patricia Leat - Réponse
How do you disconnect the quick connect
DJ SmashBeatz - Réponse
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - Réponse
Same here. Worst design ever.
James Watson -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 151
30 derniers jours : 753
Total : 44,803
