Introduction
If the LED light in the drill no longer turns on, you can use this guide to easily replace it with a new one.
Ce dont vous avez besoin
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
The black plastic piece is the housing. The light is placed inside this black plastic housing.
2 autres ont terminé cette réparation.
