Introduction
If the motor of the drill stops working, this guide will show you how to remove the motor of the black and decker Pivot Plus PD600 whether for repair, or for other use.
Pièces
Aucune pièce nécessaire.
Remove the nine 15mm Philips #1 screws Remove the two 12.5mm Philips #1 screws Remove the two 10mm Philips #1 screws
  • Remove the nine 15mm Philips #1 screws
  • Remove the two 12.5mm Philips #1 screws
  • Remove the two 10mm Philips #1 screws
Ajouter un commentaire
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
  • After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
  • However, do not pull too hard because the motor is attached to other components of the drill by wires.
After taking out the motor, you can observe  two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed. Mark or color code the black and red wires so you can return them to the correct position.
  • After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
    • Mark or color code the black and red wires so you can return them to the correct position.
Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
  • Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
4 autre(s) ont terminé cette réparation.
Jonathon Centofranchi
Membre depuis le 19/04/2013
219 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-15, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 membres
6 tutoriels rédigés
If my motor try to turn is there anything I can do to fix-it? :)
Kenny Ray Carder - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 770
