Introduction
The pivot button may need to be installed if problems such as jamming of the button occur. This guide will outline how to install the pivot button on the Black and Decker Pivot Plus PD600.
Pièces
Aucune pièce nécessaire.
Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
  • Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
Ajouter un commentaire
After the screw is removed, take off both sides of the button.
  • After the screw is removed, take off both sides of the button.
  • You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
Ryan Angelich
Membre depuis le 13/05/2013
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-15, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 721
