Introduction
We will show you how to replace the heat controls for the oven and toaster settings. You will have to pop off the control knobs, take off the top cover, and remove screws in order to get to the controls. If your timer is not working, then unfortunately you will need to buy a new toaster over. Make sure you to place the screws back in the correct places and not to rip the heat shielding.
Ce dont vous avez besoin
Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
Remove the two 5.5mm screws, that are holding the oven controls to the face, using a #2 Phillips head screwdriver.
3 commentaires
Hi Alejandro, could you tell me how to replace the heating elements. Or maybe just how to access them for better cleaning? Or maybe just suggestions on how to clean them while in place since they do rotate? Vinegar-water isn’t working. Thanks!!!
Where can I get a new toast/ heater control unit?
