Aller au contenu principal
Introduction
Before replacing knobs you will have to disassemble oven to take off the knobs and faceplate.
Pièces
Aucune pièce spécifiée.
  1. Make sure that the toaster is unplugged before you begin.
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Pull down and out to remove side panels from the unit Repeat for the other side.
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Remove the bottom vent.
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Remove the crumb tray (bottom metal panel) from the toaster unit.
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Remove the aluminum strip on the bottom of the unit.
    • Remove the aluminum strip on the bottom of the unit.
  7. Remove knobs by pulling up on them.
    • Remove knobs by pulling up on them.
  8. Unhook the bottom of the display panel from the toaster unit.
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
To reassemble your toaster, follow these directions in reverse.
Jonathan
Membre depuis le 18/09/2012
245 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-10, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 41
Total : 3,902
