Aller au contenu principal
Black and Decker WP900 Exterior Casing Replacement
Ce dont vous avez besoin
  1. Black and Decker WP900 Exterior Casing Replacement, Exterior Casing: étape 1, image 1 de 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Exterior Casing Replacement: étape 2, image 1 de 1
    • Using the Phillips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Exterior Casing Replacement: étape 3, image 1 de 3 Black and Decker WP900 Exterior Casing Replacement: étape 3, image 2 de 3 Black and Decker WP900 Exterior Casing Replacement: étape 3, image 3 de 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Exterior Casing Replacement: étape 4, image 1 de 1
    • Using the Phillips #1 screwdriver, remove the two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Exterior Casing Replacement: étape 5, image 1 de 2 Black and Decker WP900 Exterior Casing Replacement: étape 5, image 2 de 2
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top.
  6. Black and Decker WP900 Exterior Casing Replacement: étape 6, image 1 de 1
    • Firmly grasping the motor dislodge the internal components from the frontal external casing.
    • Once the motor has been removed, the external casing can now be replaced.
David Hutchings
Membre depuis le 03/28/16
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 8-8, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 membres
4 tutoriels rédigés
Un commentaire
Hello, this is Adam Kinnett from Group 7. You have done an excellent job on your photos as well as the descriptions and formatting.
**One of your Wiki pages on the search says "Back and Decker".
Adam Kinnett - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 890
