Aller au contenu principal
Black and Decker WP900 Power Switch Replacement
Ce dont vous avez besoin
  1. Black and Decker WP900 Power Switch Replacement, Power Switch: étape 1, image 1 de 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Switch Replacement: étape 2, image 1 de 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Switch Replacement: étape 3, image 1 de 3 Black and Decker WP900 Power Switch Replacement: étape 3, image 2 de 3 Black and Decker WP900 Power Switch Replacement: étape 3, image 3 de 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Switch Replacement: étape 4, image 1 de 1
    • Loosen the power cord and control panel. Using the Phillip's #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Switch Replacement: étape 5, image 1 de 2 Black and Decker WP900 Power Switch Replacement: étape 5, image 2 de 2
    • Gently pull the power cord out from the control module.
    • Remember, when reassembling the device, the black wire should be on the top
  6. Black and Decker WP900 Power Switch Replacement: étape 6, image 1 de 1
    • Firmly grasping the motor, dislodge the internal components from the frontal external casing.
    • Switch and control panel will be attached to magnet body.
  7. Black and Decker WP900 Power Switch Replacement: étape 7, image 1 de 1
    • Remove the switch from the wires.
    • Gently, pull and release the two wired connections.
    • The switch can now be replaced. Be sure not to damage the two connections to the control module in the process.
Cameron
Membre depuis le 02/15/16
231 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 8-8, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 987
