Introduction
The battery connector connects the battery to the logic board. This part could be the cause of battery issues. This guide will demonstrate how to replace the battery connector after the logic board has been removed.
Pièces
Aucune pièce nécessaire.
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
  • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
  • Slide the battery cover off the device.
Ajouter un commentaire
Remove the lithium-ion battery from the back of the device using your index finger.
  • Remove the lithium-ion battery from the back of the device using your index finger.
  • Hold the device with both hands.
  • Lift the SIM card holder using your thumb and index finger.
  • Remove the SIM card from the device.
  • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
  • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  • Use the plastic opening tool to pry the back case away from the front case.
  • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  • Remove the front plastic case from the metal bracket.
  • Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
  • Use a Torx T6 screwdriver to remove the 3 1/8 inch screws shown.
  • Remove the logic board with your hands.
  • To remove the battery connector simply slide it out from the metal bracket using your hand.
Andrew Catlin
Membre depuis le 11/03/2013
16 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 12-2, Benson Spring 2013 Membre de l'équipe Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 189
