Aller au contenu principal
BlackBerry 8820 Trackball Replacement
Ce dont vous avez besoin
  1. BlackBerry 8820 Trackball Replacement, Disassembling BlackBerry 8820 Outer Casing: étape 1, image 1 de 1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Trackball Replacement: étape 2, image 1 de 2 BlackBerry 8820 Trackball Replacement: étape 2, image 2 de 2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Trackball Replacement: étape 3, image 1 de 2 BlackBerry 8820 Trackball Replacement: étape 3, image 2 de 2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Trackball Replacement: étape 4, image 1 de 1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Trackball Replacement: étape 5, image 1 de 1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Trackball Replacement, Track Ball: étape 6, image 1 de 1
    • After removing the front from the outer casing, the track ball will come off attached to the casing.
  7. BlackBerry 8820 Trackball Replacement: étape 7, image 1 de 1
    • Remove the track ball from the front case.
3 autres ont terminé cette réparation.
ryan
Membre depuis le 04/12/13
44 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 13-64, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 870
