Aller au contenu principal
BlackBerry Bold 9700 Memory Card Socket Replacement
Ce dont vous avez besoin
  1. BlackBerry Bold 9700 Memory Card Socket Replacement, Motherboard Housing: étape 1, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement, Motherboard Housing: étape 1, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement, Motherboard Housing: étape 1, image 3 de 3
    • Remove the battery by prying the bottom of the battery upward.
    • Once the battery is angled up, pull it away from the top of the device.
    • Be sure to remove all power sources before working on electronic devices to avoid harming yourself or the device.
  2. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 2, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 2, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 2, image 3 de 3
    • Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
    • You must remove the SIM card before you can fully disassemble the device. Failure to do so may cause damage to components later on in this process.
  3. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 3, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 3, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 3, image 3 de 3
    • Pry off the AT&T logo panel with the plastic opening tool.
    • You will hear a snapping sound as the plastic tabs pop out.
  4. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 4, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 4, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 4, image 3 de 3
    • Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
  5. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 5, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 5, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 5, image 3 de 3
    • Use the plastic opening tool to remove the frame of your device.
    • You will hear a snapping sound as the tabs pop out.
    • Once the case is loosened from the device, slide the case away from the top of the phone.
  6. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 6, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 6, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 6, image 3 de 3
    • Gently lift the bottom of the keyboard upward.
    • Pull the keyboard away from the bottom of the LCD display and lift upward.
  7. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 7, image 1 de 2 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 7, image 2 de 2
    • Remove the two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
  8. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 8, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 8, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 8, image 3 de 3
    • Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
    • Ribbon connectors are fragile. Too much force in the wrong place will damage the ribbon and may force you to replace an entire assembly.
  9. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 9, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 9, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 9, image 3 de 3
    • Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
    • You should now have two 5.57mm black torx head screws and four 4.13mm steel Torx head screws off to the side. Do not lose them.
    • Lift the clear plastic cover directly upward.
  10. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 10, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 10, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 10, image 3 de 3
    • Grip the motherboard by the screen
    • Lift the board away from the base of the housing and vertically up.
  11. BlackBerry Bold 9700 Memory Card Socket Replacement, Memory Card Socket: étape 11, image 1 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement, Memory Card Socket: étape 11, image 2 de 3 BlackBerry Bold 9700 Memory Card Socket Replacement, Memory Card Socket: étape 11, image 3 de 3
    • Use plastic opening tool to pry away tiny metal arm that is holding the socket in place.
    • Lift SD memory card socket away from phone housing till it is removed.
  12. BlackBerry Bold 9700 Memory Card Socket Replacement: étape 12, image 1 de 2 BlackBerry Bold 9700 Memory Card Socket Replacement: étape 12, image 2 de 2
    • Align new SD memory card socket into the socket housing and connect tiny metal arm.
    • Apply pressure to the top of new SD Memory card socket.
    • Once the SD memory card socket is correctly placed in the housing you are done.
Danny
Membre depuis le 03/11/15
365 Réputation
3 tutoriels rédigés
Équipe
Colorado Springs, Team 9-3, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 9-3, Panko Spring 2015
UCCS-PANKO-S15S9G3
2 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 10
Total : 1,324
