Introduction
Use this guide to replace the motherboard of your BlackBerry Curve 8520.
Ce dont vous avez besoin
Insert a plastic opening tool into the small notch on the rear cover of the phone.
Pry the rear cover up from the phone.
Locate the slit between the top of the battery and the casing.
Gently apply pressure on the top of the battery to trigger the spring release.
Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
Remove the four T6 Torx screws from the corners of the keyboard.
32 autres ont terminé cette réparation.
