Introduction
Both front and back cameras are connected as a single assembly and must be replaced together.
Ce dont vous avez besoin
Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
Remove the battery connector using either your fingers or a pair of tweezers.
Remove the flat-top connector coming from across the camera assembly with a spudger.
With the spudger, remove the flat-top connector coming from underneath the motherboard.
Remove the clipped ZIF data connector coming from underneath the motherboard.
Lift up the black plastic clip with a spudger.
Pull the connector out gently using tweezers.
Remove the following five screws from the motherboard.
Three 1.5x2.5mm Phillips screws
Two 1.55x2.38mm Phillips screws
Lift all four antenna connectors from the motherboard again using the spudger.
Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
Pry the camera assembly away from the device, lifting the left side with a spudger.
Insert spudger between the plastic frame and circuit board.
Gently pry the plastic frame away from the rest of the camera assembly.
2 autres ont terminé cette réparation.
