Pièces
Aucune pièce nécessaire.
  1. Depress the battery cover release button and remove the battery cover
    • Depress the battery cover release button and remove the battery cover
    • Remove the battery from the phone before continuing.
    • Slide the yellow button toward the battery to eject the SIM card
    • Remove the MicroSD card from the SD slot (if present)
  2. There will be a silver bezel around the edge (the dog ate mine!)
    • There will be a silver bezel around the edge (the dog ate mine!)
    • Insert pry tool near the padlock icon and gently work your way around the bezel to pry it off and reveal the screws.
    • Grab your T5 Torx screwdriver, and remove all 8 screws
    • Be careful when taking out screws. The silver ones go in the corners, black ones in the middle
    • With the 8 screws removed, you can gently pry the back cover off. Be gentle, as it is still connected by a ribbon cable
    • Gently pry ribbon cable off, and then you will have the back cover fully removed
    • The next step is to remove the board.
    • There are 3 ribbon cables connected to it
    • Disconnect the first ribbon cable
    • When you remove the second ribbon cable it will reveal the third ribbon cable
    • With the 3 ribbon cables disconnected you can gently pry the board up and away from phone
    • With the board removed, you can then simply lift out the LCD display
    • Once the LCD is removed, the handset disassembled.
7 autre(s) ont terminé cette réparation.
daniel
Membre depuis le 22/12/2011
382 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 6,548
