Aller au contenu principal
BlackBerry Tour 9630 Trackball Replacement
Ce dont vous avez besoin
  1. BlackBerry Tour 9630 Trackball Replacement, Battery: étape 1, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement, Battery: étape 1, image 2 de 2
    • Flip phone over so the back side is facing up.
  2. BlackBerry Tour 9630 Trackball Replacement: étape 2, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement: étape 2, image 2 de 2
    • Push up on the center silver button to release the back cover.
    • Remove the back cover.
  3. BlackBerry Tour 9630 Trackball Replacement: étape 3, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement: étape 3, image 2 de 2
    • Grip the battery where the light grey half circles are located and pull up on the battery.
    • Remove the battery.
  4. BlackBerry Tour 9630 Trackball Replacement, Keypad: étape 4, image 1 de 1
    • If there is an SD card, press gently on the card and slide up to remove.
    • If there is a SIM card, press gently on the card and slide left to remove.
    • Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
  5. BlackBerry Tour 9630 Trackball Replacement: étape 5, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement: étape 5, image 2 de 2
    • Using the large blue plastic opening tool, pry the top plastic covering off.
    • There is glue holding the top plastic covering. Additional pressure may be needed.
  6. BlackBerry Tour 9630 Trackball Replacement: étape 6, image 1 de 1
    • Use the T6 Torx screwdriver to remove the two 8.00mm screws from the top of the phone.
  7. BlackBerry Tour 9630 Trackball Replacement: étape 7, image 1 de 1
    • Remove the back casing by wiggling it open.
  8. BlackBerry Tour 9630 Trackball Replacement: étape 8, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement: étape 8, image 2 de 2
    • Using the small plastic opening tool, pry up the pop ribbon cable from the motherboard.
  9. BlackBerry Tour 9630 Trackball Replacement: étape 9, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement: étape 9, image 2 de 2
    • Using the small plastic opening tool, remove the side antenna cable.
  10. BlackBerry Tour 9630 Trackball Replacement: étape 10, image 1 de 1
    • Gently push up on the keyboard and snap the front cover off.
    • Once you remove the front cover, the keypad and trackball will be loose.
  11. BlackBerry Tour 9630 Trackball Replacement: étape 11, image 1 de 1
    • Remove the keypad.
  12. BlackBerry Tour 9630 Trackball Replacement, Trackball: étape 12, image 1 de 2 BlackBerry Tour 9630 Trackball Replacement, Trackball: étape 12, image 2 de 2
    • Remove the trackball.
Mia
Membre depuis le 01/13/15
524 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 705
