Aller au contenu principal
BlackBerry World Edition 8830 Trackball Replacement
Ce dont vous avez besoin
  1. BlackBerry World Edition 8830 Trackball Replacement, Trackball: étape 1, image 1 de 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: étape 1, image 2 de 3 BlackBerry World Edition 8830 Trackball Replacement, Trackball: étape 1, image 3 de 3
    • Make sure the phone is powered off before removing the trackball.
    • Gently use the Small Flathead Screwdriver or plastic opening tool to go under the chrome ring surrounding the trackball.
    • Pry the chrome ring upwards with the tool until it begins to lift up.
    • Once it begins to lift up, gently remove the chrome ring from around the trackball.
    • When re-assembling the phone, be sure to orient the chrome ring so that the missing tab is at the top.
  2. BlackBerry World Edition 8830 Trackball Replacement: étape 2, image 1 de 2 BlackBerry World Edition 8830 Trackball Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • After removing the chrome ring, slowly lift up the remaining piece with tweezers.
    • Slowly remove the small plastic bottom using the Plastic Opener tool. Be careful not to bend the metal frame when removing the bottom plastic piece.
    • Using your hands, remove the white plastic piece, revealing the small metal frame, the scroll wheels, and the trackball.
  3. BlackBerry World Edition 8830 Trackball Replacement: étape 3, image 1 de 1
    • Slowly remove the trackball, being cautious not to scratch the ball or the scroll wheels.
    • Using a soft cloth, carefully remove any dust around the scroll wheels or the trackball itself.
    • While the trackball is removed, you may clean the sensor in the hole where the trackball is usually located.
tbace
Membre depuis le 04/18/12
28 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-27, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 1,072
