Aller au contenu principal
BlackBerry Z30 Logic board Replacement
Ce dont vous avez besoin
  1. BlackBerry Z30 Logic board Replacement, Battery cover: étape 1, image 1 de 1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: étape 2, image 1 de 1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: étape 3, image 1 de 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: étape 3, image 2 de 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: étape 3, image 3 de 3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: étape 4, image 1 de 2 BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: étape 4, image 2 de 2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Logic board Replacement, Remove the LCD: étape 5, image 1 de 2 BlackBerry Z30 Logic board Replacement, Remove the LCD: étape 5, image 2 de 2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: étape 6, image 1 de 1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Logic board Replacement, Untie the System board: étape 7, image 1 de 1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: étape 8, image 1 de 1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: étape 9, image 1 de 1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Logic board Replacement, System board removal: étape 10, image 1 de 1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
4 autres ont terminé cette réparation.
Hans
Membre depuis le 10/20/14
1 920 Réputation
6 tutoriels rédigés
Équipe
Mero IT Services Membre de l'équipe Mero IT Services
Business
1 membre
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 4,004
