Aller au contenu principal
Introduction
If you are removing the keypad to clean or replace it, this guide is for you.
Pièces
Aucune pièce spécifiée.
  1. Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone. Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Use a pick or plastic opening tool to push the clips holding the rear away from you. Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Repeat the process of unlatching the clips for the top section of the Blackberry.
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  7. Slide the rear panel forward to reveal the motherboard. Slide the rear panel forward to reveal the motherboard.
    • Slide the rear panel forward to reveal the motherboard.
  8. Remove the indicated screws using a T6 Torx screwdriver. Remove the indicated screws using a T6 Torx screwdriver.
    • Remove the indicated screws using a T6 Torx screwdriver.
  9. Remove the motherboard. Remove the indicated screw using the T6 Torx screwdriver.
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  10. Pull the metal plate away from the front panel of the cell phone. Pull the metal plate away from the front panel of the cell phone.
    • Pull the metal plate away from the front panel of the cell phone.
  11. Place the faceplate face-down and the interior of the phone face-up, as shown.
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
  12. After removing the faceplate of the BlackBerry, place it facing down on a table as shown. Using tweezers if needed, grip the keypad by one of the plastic nubs and pull it off of the pins.
    • After removing the faceplate of the BlackBerry, place it facing down on a table as shown.
    • Using tweezers if needed, grip the keypad by one of the plastic nubs and pull it off of the pins.
    • Alternatively, you can pop the keypad out by holding the faceplate face-up and pressing the keys down. Be sure to catch the keypad when it falls out.
  13. If you are cleaning the keypad, use a fine brush to wipe any dirt from both the front and back of the pad.
    • If you are cleaning the keypad, use a fine brush to wipe any dirt from both the front and back of the pad.
    • You may also rinse the keypad with water, but make sure that it is completely dry before reinserting it on to the faceplate.
  14. To place the new or cleaned keypad in the faceplate, hold the faceplate in one hand face-down and grab the keypad by the edges in your other hand.
    • To place the new or cleaned keypad in the faceplate, hold the faceplate in one hand face-down and grab the keypad by the edges in your other hand.
    • Align the holes in the keypad over the black pins in the faceplate and press down on the keypad until it is firmly in place. Flip the faceplate over to make sure that the keys are properly aligned.
Nathan
Membre depuis le 18/01/2010
31 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-7, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,131
