Aller au contenu principal
Blackberry 8700c Battery Replacement
  1. Blackberry 8700c Battery Replacement, Battery: étape 1, image 1 de 3 Blackberry 8700c Battery Replacement, Battery: étape 1, image 2 de 3 Blackberry 8700c Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
  2. Blackberry 8700c Battery Replacement: étape 2, image 1 de 2 Blackberry 8700c Battery Replacement: étape 2, image 2 de 2
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
    • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
    • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
Membre depuis le 10/28/09
42 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-4, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 2,819
