Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
  1. Place your Blackberry facedown in front of you.
    • Place your Blackberry facedown in front of you.
  2. Press the cover release button on the bottom of your device. Lift and remove the back cover.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. From the top, use your fingernail to lift the battery out.
    • From the top, use your fingernail to lift the battery out.
  4. Remove the SIM card.
    • Remove the SIM card.
  5. Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Use the plastic opening tool to remove the rear case.
    • Use the plastic opening tool to remove the rear case.
  7. Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Locate the volume toggle on the main frame of the phone.
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
2 autre(s) ont terminé cette réparation.
Kelly
Membre depuis le 18/01/2012
566 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-17, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 2,331
